| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | My 50 chevy 3100 has a little bit of play in the original steering . I tried to adjust the steering box and it helped some. I know I brought some of this on with a wider than stock size tire installed. I was wondering if any one has ever installed a stabilizer shock on their steering like what you see commonly on 4 wheel drive vehicle to aid in steering performance when larger tires are added to a 4 wheel drive? Would this additional component help with my steering drift that I experience when driving this machine? | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I have installed one on my 51 Panel truck. I have the original style axle & springs, but, have upgraded the steering to modern GM power steering with disc brakes. I use 245x75x16R Michelin LTX truck tires on 8 inch rims…….. BIG!
The steering stabilizer has helped the truck stay on center and "feel" more solid and predictable.
Hope this helps. mike
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I put one on a pickup without power steering & it made it worse. You had to pull it back after a turn. It was downright dangerous. You need to check all you linkage & possibly o-haul the steering box. You need to get all the play out. You may need to add shims to increase the caster. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Find a better steering box.
| | | | | Joined: Jun 2011 Posts: 291 'Bolter | | 'Bolter Joined: Jun 2011 Posts: 291 | I have front disc brakes and I may need to try adjusting the steering box again. What steering boxes will fit this truck? Should I look for manual steering boxes from a newer truck or does someone sell replacement parts or whole units to replace the original steering boxes? | | |
