7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible), 90 guests, and 3 robots.
Topics128,045
Posts1,055,528
Members48,424
My 50 chevy 3100 has a little bit of play in the original steering . I tried to adjust the steering box and it helped some. I know I brought some of this on with a wider than stock size tire installed. I was wondering if any one has ever installed a stabilizer shock on their steering like what you see commonly on 4 wheel drive vehicle to aid in steering performance when larger tires are added to a 4 wheel drive? Would this additional component help with my steering drift that I experience when driving this machine?
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
I have installed one on my 51 Panel truck. I have the original style axle & springs,
but, have upgraded the steering to modern GM power steering with disc brakes.
I use 245x75x16R Michelin LTX truck tires on 8 inch rims…….. BIG!
The steering stabilizer has helped the truck stay on center and "feel" more solid and predictable.
Hope this helps.
mike
Riding in the Passing Lane
I put one on a pickup without power steering & it made it worse. You had to pull it back after a turn. It was downright dangerous. You need to check all you linkage & possibly o-haul the steering box. You need to get all the play out. You may need to add shims to increase the caster.
1972 Chevy c10 Cheyenne Super
Find a better steering box.
I have front disc brakes and I may need to try adjusting the steering box again. What steering boxes will fit this truck? Should I look for manual steering boxes from a newer truck or does someone sell replacement parts or whole units to replace the original steering boxes?
1950 Chevy 3100
In the DITY Gallery
2000 Tahoe
