1 members (Rnl364),
104
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | I'm debating on "fixing" the rear frame on my COE. Is the vertical part original? I don't think the angle iron crossmember is original (where the hitch is welded on). Does anyone have a picture of original? Also, any ideas on straightening the bent channel crossmember? Rear Frame Rear Frame 2 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the vertical C channel pieces are what was cut off the ends of the frame to make the hitch, rest is what was handy to complete the butchery
Bill | | | | | Joined: Jun 2005 Posts: 116 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 116 | What is the original length from, let's say, the center of the rear spring hanger?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | should be able to sort it out from the GM resto kit chassis dimensions and wheelbase info Bill | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Looks like the P.O.cut the end of the frame off to make a "trailer hitch". Take a measurement of your frame,then add the length of the remaining frame,(vertical pieces). That's the original length of your frame. | | | | | Joined: Mar 2013 Posts: 176 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 176 | My COE was also "modified" similarly. It was also cut behind the cab and shortened. I left mine short as I just want a big pick-up.
I like the Blue motor can't wait to see more pics as you go further into the build. | | |
