3 members (Gdads51, Raymond HAYWOOD, IHPWR), 175 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1066707 11/05/2014 9:28 PM
I'm debating on "fixing" the rear frame on my COE. Is the vertical part original? I don't think the angle iron crossmember is original (where the hitch is welded on). Does anyone have a picture of original?
Also, any ideas on straightening the bent channel crossmember?
Rear Frame
Rear Frame 2
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
the vertical C channel pieces are what was cut off the ends of the frame to make the hitch, rest is what was handy to complete the butchery
What is the original length from, let's say, the center of the rear spring hanger?
1962 IH Scout 80
should be able to sort it out from the GM resto kit chassis dimensions and wheelbase info
Looks like the P.O.cut the end of the frame off to make a "trailer hitch". Take a measurement of your frame,then add the length of the remaining frame,(vertical pieces). That's the original length of your frame.
Mo' Tater
My COE was also "modified" similarly. It was also cut behind the cab and shortened. I left mine short as I just want a big pick-up.
I like the Blue motor can't wait to see more pics as you go further into the build.
