| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | My 55.2 3100 3 speed trans has a 4 bolt side cover with one shift arm up and one shift arm down. 56 up has both shift arms down. So my question, is my side cover set up a one year only, or can I get a cover from and older truck that will fit (work) with my three speed?
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The one up-one down setup was used on ADs. I'm surprised '55 second used it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 55.2 uses it because of the configuration of the shift rods that use an intermediate pivot point, the 4 bolt covers are all the same, but the linkage movement is different so the arms face different - was changed for '56 to eliminate that intermediate bellcrank pivot
Bill | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | So would it be safe to say that if I changed the pivot rod set up, and got a 2nd-3rd 1 piece rod, I could use a 56 and up trans with both shift arms facing down?
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can use the side cover from an earlier truck on your trans since they both have the up/down configuration. However, you will need to use the L/R shift fork from the TF side cover as the shift fork on the AD trans is narrower to accommodate the narrower slider gear. Fred
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can also use the 56 side cover and the one piece rod. 56 up (and 55 V-8's) used a different shifter box to allow clearance for the V-8 exhaust manifold. This should not be an issue with the 235. Fred
