0 members (), 45 guests, and 3 robots.
Topics128,049
Posts1,055,637
#1066593 11/05/2014 3:51 AM
My 55.2 3100 3 speed trans has a 4 bolt side cover with one shift arm up and one shift arm down. 56 up has both shift arms down. So my question, is my side cover set up a one year only, or can I get a cover from and older truck that will fit (work) with my three speed?
Brian
Brian
1955.2 3100 Truck
55shaker #1066610 11/05/2014 4:55 AM
The one up-one down setup was used on ADs. I'm surprised '55 second used it.
55shaker #1066614 11/05/2014 5:00 AM
55.2 uses it because of the configuration of the shift rods that use an intermediate pivot point, the 4 bolt covers are all the same, but the linkage movement is different so the arms face different - was changed for '56 to eliminate that intermediate bellcrank pivot
55shaker #1066671 11/05/2014 5:12 PM
So would it be safe to say that if I changed the pivot rod set up, and got a 2nd-3rd 1 piece rod, I could use a 56 and up trans with both shift arms facing down?
Brian
Brian
1955.2 3100 Truck
55shaker #1066673 11/05/2014 5:16 PM
You can use the side cover from an earlier truck on your trans since they both have the up/down configuration.
However, you will need to use the L/R shift fork from the TF side cover as the shift fork on the AD trans is narrower to accommodate the narrower slider gear.
Fred
55shaker #1066676 11/05/2014 5:35 PM
You can also use the 56 side cover and the one piece rod.
56 up (and 55 V-8's) used a different shifter box to allow clearance for the V-8 exhaust manifold. This should not be an issue with the 235.
Fred
