Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#1065706 10/31/2014 8:58 PM
Are the TF frames from different years all alike? More specifically, can the cab and front sheet metal parts from a '57 fit onto a '59 frame? Thanks for any advice.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1065793 11/01/2014 4:07 AM
3B Offline
Hy jfnar, unfortunately the 58 and 59 front sheet metal is longer than the 55B through 57, and therefore the 58 and 59 frames are longer at least from the cab forward, sorry to deliver the bad news.
jfnar #1065800 11/01/2014 4:43 AM
not real bad news tho, the 8/9 frame is only longer in front of the rad, just needs to be cut back a couple inches with new holes drilled to mount the front bumper brackets - pic here of '57 front clip on '58 frame
jfnar #1065927 11/01/2014 10:17 PM
Thanks for the info. I thought there was a difference but I couldn't remember what it was. I can probably deal with that. One more frame related question: Are the frames under panel trucks the same as pickup trucks? I think I know where there's a 56 panel for parts. Thanks again.
Jeff
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #1065932 11/01/2014 10:25 PM
mostly the same except for different body mounts and the panel frame has extensions on the back of the frame to position the bumper correctly, the rear extensions [riveted on] can be cut off, but you'd need the pickup body mount brackets to add to the panel frame - also the panel has a frame mounted gas tank that might be made to work for a pickup, but would be easily sold
