| | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Are the TF frames from different years all alike? More specifically, can the cab and front sheet metal parts from a '57 fit onto a '59 frame? Thanks for any advice.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jfnar, unfortunately the 58 and 59 front sheet metal is longer than the 55B through 57, and therefore the 58 and 59 frames are longer at least from the cab forward, sorry to deliver the bad news. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not real bad news tho, the 8/9 frame is only longer in front of the rad, just needs to be cut back a couple inches with new holes drilled to mount the front bumper brackets - pic here of '57 front clip on '58 frameBill | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks for the info. I thought there was a difference but I couldn't remember what it was. I can probably deal with that. One more frame related question: Are the frames under panel trucks the same as pickup trucks? I think I know where there's a 56 panel for parts. Thanks again.
Jeff
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | mostly the same except for different body mounts and the panel frame has extensions on the back of the frame to position the bumper correctly, the rear extensions [riveted on] can be cut off, but you'd need the pickup body mount brackets to add to the panel frame - also the panel has a frame mounted gas tank that might be made to work for a pickup, but would be easily sold
Bill | | |
