3 members (Hotrod Lincoln, Ponchogl, 1 invisible), 40 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#106569 11/24/2001 2:16 AM
I am about to paint the dash on my 51. Was the entire dash powder coated orginally? If so, was the color brown? It is a fine rust color presently. Also, was a hammer finish used? Thanks.
#106570 11/24/2001 2:50 AM
I'm not an expert, but I don't think powder-coating was around in 1951, at least for automobile/trucks. The dash paint for 47-53 is a semi-flat, gray-brown, lacquer, with a slight metallic tinge. As far as I know, only the heater used a hammer-finish, and that is more of a brown with a silver or bronze tinge. Both original colors are available from Jim Carter, and probably other suppliers.
#106571 11/25/2001 4:58 PM
The color is "Champagne." Chevy Duty sells it in acrylic enamel. It should be flat, I find that it's a bit too flat, so I have successfully polished it out just a little to get the right luster.
#106572 11/30/2001 12:00 AM
V
V Offline
The finish you are thinking of is called Hammerite. They are still in business and they even have a website. It comes in a vareity of colors/mixes. No, it was not used on the dash. They only used it on the heater.
