2 members (JW51, WICruiser), 300 guests, and 7 robots.
Topics128,078
Posts1,056,036
Members48,433
#1065513 10/30/2014 9:42 PM
Went to visit the guys who are supposed to be re-assembling my suspension, driveline, etc. Theytold me that as the disassembled everything they took extensive pictures so they would have a guide to putting it all back together. Well, the guy's cell phone crashed and none of the pics were backed up!!
So I've been running around trying to get pictures of assembled front suspension with not much luck so far.
Can anyone point me to suspension pictures, or, better yet, any exploded views of how all this goes back together? of particular interest would be the how the tie rods, drag links, brake backing plate and spindles go back together. thanks
Do you have a copy of a 1958 Shop Manual and/or the 55-59 Factory Assembly Manual? Maybe someone who does will tell you page numbers and/or post links to appropriate pages. Neither of those documents are on-line.
Learn a lesson for the future: if a shop is taking photos with a phone, ask them to email the photos to you. I feel your pain, regarding the lost photos.
Good luck,
the '55 manual here will have a range of pictures of the front end, same as a '58 otherwise you need the 5-9 factory assembly manual .... not sure I'd want to be dealing with a mechanical shop that needs pictures to know how something they took apart goes back together frown
I hear you. I forgot to mention that I have both the assembly and shop manual but the pics are so poor as to be unuseable. I'll check the online one. Thanks
the assembly manual should be quite clear if you find the proper pages, even calls out nuts and bolts and washers .... section 3 front suspension, section 5 brakes, section 9 steering gear ... take them the manual and point out the sections, if they can't figure it out gather up the pieces and take it elsewhere!
