0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | My plan is to put a Chevy 350 V8 and 700r4 in my '53 3100.
The brake system will most likely be disk on front IFS and drum on rear.
The Master Cylinder will have to be replaced, I plan to use a dual with booster.
My question is, what are the pros and cons of leaving the MC under the cab (retaining the through the floor brake pedal that I think is so cool) VS moving it up to the firewall (modern location and brake pedal)?
Anyone who has put a small block chevy V8 in an Advance Design pickup, please share your thoughts.
Thank You Tim
'53 3100 5-window '57 Mercury Monterey 2-Door Sedan Tim H
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, there have probably been countless V8's put in AD style pickups including my own. My preference is to put the m/c and booster under the floorboard. I did this on both my 37 and my 52panel. I just like the "clean" firewall. A kit is made and available from several vendors that come with the m/c, booster, chassis bracket and a fabricated brake pedal. I used one from piratejack.net located in Asheville, N.C. Good price and quality. I'll admit that under the floor is a little hard to get to but honestly, how many times do we have to check the m/c.
The firewall mounts MIGHT be a bit easier to put in and have the swinging pedal... and easier to get to. In the end I guess it is personal choice.....but most of the time its crowded enough under the hood without the m/c and booster there to. | | | | | Joined: Oct 2014 Posts: 136 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 136 | I agree and I would prefer to leave it under the cab because I like the original through the floor brake pedal.
The two drawbacks I see from leaving it under the floor is (1) not so easy to check and add brake fluid and (2)room for exhaust pipe. That's why I asked for comments from those who have been there and done that.
Thank You Tim
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Both my '48 Burb and my son's '53 P/U are under the floor. The kits are pricey but it retains a bit of the querkiness of the truck.
