| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 9 Junior Member | | Junior Member Joined: Aug 2004 Posts: 9 | Perhaps this is an easy one; Does the door on my truck´s box should have the chevrolet lettering stamped? Or should it be plain?
In case it should have the lettering; are the letters painted body color or moulding color?
Thanks for the help.
Greetings.
Lucas. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Lucas - I think you are refering to the tailgate of the bed, right. Originally the 41-46 tailgates were plain no lettering at all. The 39s had the chevrolet script lettering and the 47 ADs had the embossed block lettering. Hope this helps George | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Unless of course it was a GMC, which would have had script and it would have been painted white or black depending upon the base color.  | | | | | Joined: Aug 2004 Posts: 9 Junior Member | | Junior Member Joined: Aug 2004 Posts: 9 | I was thinking in spanish when I wrote box door (its tapa(or puerta meaning tailgate) de caja (box))!!!
Thanks for your help. Look like I´m not buying that "chevrolet" tailgate!!!
Lucas | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tailgates were plain on 37's to but if you order a replacement they are offered with the lettering stamped in it in case you want it..just info. | | |
