| | | Forums66 Topics128,120 Posts1,056,319 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I saw an episode on dream car garage today, they were showing a dry sanding system using a da sander and 1200 grit paper for sanding orange peel. Has anyone used this or know anything about it? With problems in both shoulders, I need all the help I can get out of power tools.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | It isn't a "DA" that they were using. It was a random orbital sander. And a "finish" sander at that. It is a sander that has a much finer cut than a regular da and actually works very well. There are a number of manufactures that make "innerface" pads made of foam that goes between the paper and the pad so it doesn't cut to much on edges and body lines. It really is a cool way to color sand. Instead of polishing out sand scratches you are polishing out a "haze" and it works much better.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I wuz gonna say....... cutting & buffing with a DA could be dangerous. Especially on sharp edges & corners. Cutting is best done by hand. You can use all the power tools ya want to polish. | | |
