3 members (Peggy M, FAST55, Hotrod Lincoln), 68 guests, and 2 robots.
Topics128,050
Posts1,055,759
#106521 09/16/2002 5:59 AM
I saw an episode on dream car garage today, they were showing a dry sanding system using a da sander and 1200 grit paper for sanding orange peel. Has anyone used this or know anything about it? With problems in both shoulders, I need all the help I can get out of power tools.
Fred
52 3600
69 C-10
#106522 09/16/2002 7:03 AM
It isn't a "DA" that they were using. It was a random orbital sander. And a "finish" sander at that. It is a sander that has a much finer cut than a regular da and actually works very well. There are a number of manufactures that make "innerface" pads made of foam that goes between the paper and the pad so it doesn't cut to much on edges and body lines. It really is a cool way to color sand. Instead of polishing out sand scratches you are polishing out a "haze" and it works much better.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#106523 09/20/2002 4:12 AM
Anonymous
Unregistered
Anonymous
Unregistered
I wuz gonna say....... cutting & buffing with a DA could be dangerous. Especially on sharp edges & corners.
Cutting is best done by hand. You can use all the power tools ya want to polish.
