2 members (klhansen, TUTS 59), 64 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#1064850 10/27/2014 8:22 PM
Hi
37 Chev 1/2 ton
While adding brake lights, I discovered the brake light switch on the end of the brake cylinder wasnt working when brake peddle depressed.The feed wire shows 6 volts the other side 2. if I manually connect the two wires the brake lights work.
I also tried a brand new pressure switch. This didnt work either
Is there something else I should be checking
(note brakes work well just no brake light(
Riding in the Passing Lane
Remove the switch & see if any fluid comes out when you put a little pressure on the pedal. If not something is plugged up. If some comes out you have a defective new switch
1972 Chevy c10 Cheyenne Super
Ex Hall Monitor
Ex Hall Monitor
All pressure switches aren't created equal. My experience with pressure switches is that even low pressure switches 'go bad' because you have to start pressing the pedal harder and harder to get them to activate. I converted my '38 to a newer lever switch and am MUCH happier.
Thanks all for replying
