| | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Hi 37 Chev 1/2 ton While adding brake lights, I discovered the brake light switch on the end of the brake cylinder wasnt working when brake peddle depressed.The feed wire shows 6 volts the other side 2. if I manually connect the two wires the brake lights work. I also tried a brand new pressure switch. This didnt work either Is there something else I should be checking (note brakes work well just no brake light( | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Remove the switch & see if any fluid comes out when you put a little pressure on the pedal. If not something is plugged up. If some comes out you have a defective new switch They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | All pressure switches aren't created equal. My experience with pressure switches is that even low pressure switches 'go bad' because you have to start pressing the pedal harder and harder to get them to activate. I converted my '38 to a newer lever switch and am MUCH happier.
| | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | | | |
