4 members (baldeagle, Napco Man, stlcardinalsguy, walter74), 88 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#106511 04/17/2004 11:09 PM
the stamped marking behind the distrator is LA0552264. does this engine match a 52 chevy 5 window 1/2 ton PU? if not what size is it? thanks and i hope i am not bugging yall too much.
Get busy liv'n or get busy die'n
#106512 04/18/2004 2:26 AM
Well, this is what my book says. "L" means it's a '53. "A" means it's a 216.5 CID. "O" is not listed as an option. If it's a "G" that means it was built in the Flint plant. The numbers are unit numbers. It says it had 92H.P. and 6.6:1 comp. ratio and a 1 BC carb set up. Hope this helps,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
