0 members (),
122
Mod | | | Forums66 Topics128,131 Posts1,056,727 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Hi, I have a 1946 2 ton and I'm trying to remove the tank. I took the 4 straps/bars off but the tank doesn't budge. What am I missing? Thanks!
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | 2 ton trucks were available with tanks under the seat or outside the right frame rail. Which do you have?
The underseat tank is held in place by 2 straps and four bars. There is nothing else that prevent its removal other than the plumbing and electrical connections. | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | It's under the seat. I removed the 4 bars. How do you remove the straps? It's hat to see because the crevices are caked with rotten soy beans. Am I looks for screws or bolts? And are they in the cab or beneath the truck? Thanks.
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The nuts attaching the straps are accessible on the underside of the cab. | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 |
| | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Each strap has a nut on each end, so four nuts. The straps are flexible so only one of the nuts on each strap need be removed to remove the tank. | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 |
