5 members (LAJones48, dt235sd, Samantha, mick53, 1 invisible), 175 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
#1065023 10/28/2014 5:20 PM
1 Offline
Hi, I have a 1946 2 ton and I'm trying to remove the tank. I took the 4 straps/bars off but the tank doesn't budge. What am I missing? Thanks!
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
2 ton trucks were available with tanks under the seat or outside the right frame rail. Which do you have?
The underseat tank is held in place by 2 straps and four bars. There is nothing else that prevent its removal other than the plumbing and electrical connections.
1 Offline
It's under the seat. I removed the 4 bars. How do you remove the straps? It's hat to see because the crevices are caked with rotten soy beans. Am I looks for screws or bolts? And are they in the cab or beneath the truck? Thanks.
The nuts attaching the straps are accessible on the underside of the cab.
1 Offline
2 nuts?
Each strap has a nut on each end, so four nuts. The straps are flexible so only one of the nuts on each strap need be removed to remove the tank.
1 Offline
Thank you!!
