| | | Forums66 Topics128,159 Posts1,057,027 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Guys,
I'm about to embark on plumbing my shop for compressed air.
I have a hodge podge of quick connectors for my air hoses and lines. Some from Tractor Supply, some from Harbor Freight, maybe a couple others from who knows where. I have had some fly apart, some get stuck, and some that won't couple.
What brands have you bought and put into service that were durable? I know Harbor Freight is already scratched off my list. They won't get used 10 hours a day, but I would like to buy them once and be able to forget about them.
Background for the setup: I have settled on 1" black iron pipe for all the piping. once I leave the compressor I am constructing a "cooling tower" from 1" copper pipe. I have the pipe running up, over, down, over, with 4 traps/drains in the drops.
The hard line will have the air exiting in a gooseneck fashion of up, out,and down with a trap and drain at the bottom of each drop as well.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I recently switched everything in my shop to the Oetiker 3/8" Swing Coupling. Found best price here for about $20 each but I can't find them on their site right now. http://www.industrialsafety.com/Oetiker Catalog: http://www.wescoproductiontools.com/wp-content/uploads/2014/01/ATP-SwingCouplerCatalogue.pdfThen bought Milton 3/8" H style plugs (for all my tools) to go with them from http://www.tooltopia.com/MIL1837 $1.43 MIL1838 $2.44 MIL1839 $1.49 MIL1840 $1.49 Obviously their are lots of choices and styles of fittings to choose from. After my own research decided on the above combo because the couplings are very well made and there is no obstruction to air flow, you can look straight through the coupling and plug. Additionally they work with common Milton plugs, so very affordable and easy to get more when you buy more air tools. I went with 3/8" for everything, and you can get the plugs with the 1/4" NPT to use with your blow guns, die grinders and whatever else you may have had 1/4" fittings on before. Another advantage of this plan is if you don't always need the fancy Oetiker coupler for flow you can use a standard/cheaper Milton coupler with your same plugs. All together I spent $200 total for 5 couplers and 55 plugs. This setup flows a lot more than the common size couplers and is great for impact wrenches and other tools that use a lot of air. The couplings are also not very bulky, so I felt worth the higher flow for everything in the shop and not worth having two sizes of couplers and the confusion and frustration that can cause. Even if you don't swing for the Otiker couplings... I'd recommend the same 3/8" H style plugs and the standard Milton brand couplings that fit them. like I said I use some of those Milton couplings on lesser used or less demanding things, but they're still fully interchangeable with everything in the shop. And either kind of coupler in this style/size flow plenty for most anything I can imagine needing/using, plenty of overkill. Grigg | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | Interchangeable is good. I'll check those out. Thanks | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I have always had good luck with the Milton connectors. Through throwing away money, I have found that the offshore brands like sold at lowes, harbor freight, tractor supply, northern don't work as intended. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | At one time I had two different couplers. When I needed one it was always the wrong one so I threw ALL of them on the trash can, went and bought a bunch of Miltons and hadn't looked back.....and be sure to buy a few extra and put them in a drawer. | | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I've used Milton for years, wouldn't consider any off brands. | | | | | Joined: Nov 2004 Posts: 2,422 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,422 | One thing that I discovered is that you want couplers with at least 4 ball contacts. Look inside the coupler and if you only see 3 ball contacts don't buy them as they will most likely be leakers.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | We use Milton H style on our larger tools and Milton M style on smaller tools. I buy nothing but genuine Milton. Ever so often I find a deal on a dozen or so on eBay. There is no particular reason we use the H and M except that is the style we started out with almost 50 years ago and we have no reason to change. | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | We've been using the Prevost safety QD for quite a few years now with no problems. Before that, mostly Camel products. Just push in the connector and you're good to go. Push the red button and the connector pops out with no air blast. No fighting the connection. http://www.prevostusa.com/categories.php?cat=31 | | |
