4 members (Buckeye998, Bill Hanlon, Jon G, 1 invisible), 110 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
#1064446 10/25/2014 4:07 PM
One of our members has a 235 with worn lifter bores. Apparently there was a failure in the rocker oil supply. I have seen lots of discussion about boring cylinders etc. but I have not seen lifter bore problems mentioned. Is this something that is checked on a rebuild and is there a way of repairing the problem?
1951 1 Ton Completed
1 Offline
I worked for a very high end race shop for over 15 years, and the only way to do this correctly is to use a lifter truing fixture such as those made by BHJ to relocate the lifter bore angle and location precisely, otherwise you will wipe the lobe off the cam. Once that is done, the lifter bore can be bushed and re-sized. Since these lifter bore truing fixtures are only available for the more common engine like small blocks and others, someone is going to have to pony up some big bucks to have one made. At this point, it probably will be cheaper to get another block.
I know of people who have tried to do this without these special fixtures and the results were high percentages of failures.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
12 Port,
do you have any idea how often this problem would have shown up on these old sixes? I think it is the first time I have seen it discussed here.
I have not seen worn lifter bores to be a problem on these early sixes.
My Blog
What makes you believe your lifter bores are out of spec?
I've never heard of lifter bores being worn other than on race engines or severely high mile engines.
If your bores are out of spec, check out these sites.
http://www.wydendorfmachine.com/reamerkits.html
http://www.paeco.com/Valve%20lifters.htm
http://www.theengineshop.com/produc...-accessories/bronze-lifter-bushings.html
http://www.jesel.com/valvetrain/index.php/lifters/bushings
http://www.lsmeng.com/Bushings.html
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
1 Offline
Originally Posted by truckernix
12 Port,
Yeah it's probably not very common for these engines to have this issue. So repairing a block is going to be expensive and hardly cost effective.
Albert Einstein
I have only seen one post about the problem.
1 Offline
It's also possible it is and it just isn't recognized for what it is. How many people mic the lifter bores and check the lifter clearances when they rebuild an engine? Still it isn't super common, but mostly in neglected and abused engines.
Albert Einstein
