1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One of our members has a 235 with worn lifter bores. Apparently there was a failure in the rocker oil supply. I have seen lots of discussion about boring cylinders etc. but I have not seen lifter bore problems mentioned. Is this something that is checked on a rebuild and is there a way of repairing the problem? | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | I worked for a very high end race shop for over 15 years, and the only way to do this correctly is to use a lifter truing fixture such as those made by BHJ to relocate the lifter bore angle and location precisely, otherwise you will wipe the lobe off the cam. Once that is done, the lifter bore can be bushed and re-sized. Since these lifter bore truing fixtures are only available for the more common engine like small blocks and others, someone is going to have to pony up some big bucks to have one made. At this point, it probably will be cheaper to get another block.
I know of people who have tried to do this without these special fixtures and the results were high percentages of failures.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 12 Port, do you have any idea how often this problem would have shown up on these old sixes? I think it is the first time I have seen it discussed here. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have not seen worn lifter bores to be a problem on these early sixes.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | 12 Port, do you have any idea how often this problem would have shown up on these old sixes? I think it is the first time I have seen it discussed here. Yeah it's probably not very common for these engines to have this issue. So repairing a block is going to be expensive and hardly cost effective.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have only seen one post about the problem.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | It's also possible it is and it just isn't recognized for what it is. How many people mic the lifter bores and check the lifter clearances when they rebuild an engine? Still it isn't super common, but mostly in neglected and abused engines.
