0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Would like some advice on mounting ideas. Is there other ways to mount vehicle to provide more cushioning. Someone advised hockey pucks instead of wooden blocks. Front mounts are just bolts, shim and rubber pad. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm sure there are other ways but I used the correct, proper sized wooden blocks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ADLifeSupport,
What do you mean by cushioning?
1953 panel,
Is there a pad on one/both sides the wood blocks on a panel?
There is a pad on at least one side of the blocks on a 47-55 Suburban.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Yes, there were rubber pads, about 1/4" thick on top of the blocks. I had to cut new ones, used reinforced rubber. I don't remember a rubber under the block. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Is there a pad on one/both sides the wood blocks on a panel? Yes, there were rubber pads, about 1/4" thick on top of the blocks. I had to cut new ones, used reinforced rubber. I don't remember a rubber under the block. Here are the original Body to Frame Mounting Points on a 1954 Chevrolet 3105 1/2 ton Panel Truck. Body Mounting Points 1, 2, 3, 4, 5 (Diagram) Starting at #1 (Front floorboard mount) Drivers side body mounts only. Drivers Side Body Mount #1 Front Side One rubber pad Drivers Side Body Mount #1 Rear Side Drivers Side Body Mount #2 Front Side One rubber pad Drivers Side Body Mount #2 Rear Side Drivers Side Body Mount #3 Front Side Wood Block, Two rubber pads, Upper & Lower Drivers Side Body Mount #3 Rear Side Sorry can't reach in there. No Picture Drivers Side Body Mount #4 Front Side Wood Block, Two rubber pads, Upper & Lower Drivers Side Body Mount #4 Rear Side Drivers Side Body Mount #5 Front Side picture 1, One rubber pad. Drivers Side Body Mount #5 Front Side picture 2 Drivers Side Body Mount #5 Rear Side End of Frame Bonus Pictures End of Frame Cross Member Looking Towards Passenger Side Front Side Rear Cross Member, Looking Towards Passenger Side Passenger side body mounts are the same. At least on this Panel Truck, they applied two rubber pads on each of the four wood blocks. One rubber pad on top of the wood block. One rubber pad on bottom of the wood block. Body mounts 1, 2 and 5 have one single rubber pad. As far as cushioning the body more. You would attain that through the suspension system. I believe the rubber pads are for anti-squeak. Non metal to metal contact. Just try going over railroad tracks without the body mounts having rubber pads. Squeeeeeeakk bang bang! Note: Front clip mounts not shown. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Here are a couple pics of the originals and the ones I made. The originals appeared to be "nailed" to the body before the body was set onto the chassis....mine is a 52 with one piece plywood. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/100_0439.jpgNote that on my blocks they covered only half the block...to covered only what sat on the chassis, to save material. My NEW blocks I made http://i140.photobucket.com/albums/r19/LutherParris/52Panel/NEWbodyblocks001.jpgFor the cushion I have some old fire hose that has a polyester type outer layer, and the inner layer a tough rubber which looks like pieces of inner tubes. Hope this helps. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 1954 Chevrolet Panel Truck Body to Frame Mounting Points Side ViewClick on the magnifying glass icon with the plus symbol inside, upper right-hand corner of picture. To enlarge picture and get the full effect. | | |
