1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#1062758 10/17/2014 2:21 AM
I have 05 GMC Envoy buckets that are all power equipped. They have built in seat belts which is nice for this ap. Does anyone have knowledge on basic wiring to operate the seat controls? I have both pig tails attached. Also, the seats may sit a couple of inches higher than the stock seat given the height of the seat pedestal that year. I may have to consider zip cutting the floor and installing new metal. The other consideration is new mounts for the bolting part.
cheers
...do you have a ground wire from the seat to the floor?
Achipmunk #1063050 10/18/2014 10:31 PM
Not sure on the ground wire. I had a demo of seats by a fella that had an Envoy. Not sure if it has seat warmers which were controlled on the arm rest. Would have to install a switch.
cheers
They are heated seats and the ground is the seat it self via bolts. Had a chance to see the seats work, all is good.
cheers
Moderated by  ndkid275, Phak1
