2 members (Otto Skorzeny, Rusty Heaps), 134 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
#1063047 10/18/2014 10:21 PM
Would like some advice on mounting ideas.
Is there other ways to mount vehicle to provide more cushioning. Someone advised hockey pucks instead of wooden blocks. Front mounts are just bolts, shim and rubber pad.
Leo Offline
Moderator
Moderator
I'm sure there are other ways but I used the correct, proper sized wooden blocks.
ADLifeSupport,
What do you mean by cushioning?
1953 panel,
Is there a pad on one/both sides the wood blocks on a panel?
There is a pad on at least one side of the blocks on a 47-55 Suburban.
Leo Offline
Moderator
Moderator
Yes, there were rubber pads, about 1/4" thick on top of the blocks. I had to cut new ones, used reinforced rubber. I don't remember a rubber under the block.
Here are the original Body to Frame Mounting Points on a 1954 Chevrolet 3105 1/2 ton Panel Truck.
Body Mounting Points 1, 2, 3, 4, 5 (Diagram)
Starting at #1 (Front floorboard mount) Drivers side body mounts only.
Drivers Side Body Mount #1 Front Side One rubber pad
Drivers Side Body Mount #1 Rear Side
Drivers Side Body Mount #2 Front Side One rubber pad
Drivers Side Body Mount #2 Rear Side
Drivers Side Body Mount #3 Front Side Wood Block, Two rubber pads, Upper & Lower
Drivers Side Body Mount #3 Rear Side Sorry can't reach in there. No Picture
Drivers Side Body Mount #4 Front Side Wood Block, Two rubber pads, Upper & Lower
Drivers Side Body Mount #4 Rear Side
Drivers Side Body Mount #5 Front Side picture 1, One rubber pad.
Drivers Side Body Mount #5 Front Side picture 2
Drivers Side Body Mount #5 Rear Side End of Frame
Bonus Pictures
End of Frame Cross Member Looking Towards Passenger Side Front Side
Rear Cross Member, Looking Towards Passenger Side
Passenger side body mounts are the same.
At least on this Panel Truck, they applied two rubber pads on each of the four wood blocks.
One rubber pad on top of the wood block.
One rubber pad on bottom of the wood block.
Body mounts 1, 2 and 5 have one single rubber pad.
As far as cushioning the body more.
You would attain that through the suspension system.
I believe the rubber pads are for anti-squeak. Non metal to metal contact.
Just try going over railroad tracks without the body mounts having rubber pads.
Squeeeeeeakk bang bang!
Note: Front clip mounts not shown.
Here are a couple pics of the originals and the ones I made.
The originals appeared to be "nailed" to the body before the body was set onto the chassis....mine is a 52 with one piece plywood.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/100_0439.jpg
Note that on my blocks they covered only half the block...to covered only what sat on the chassis, to save material.
My NEW blocks I made
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/NEWbodyblocks001.jpg
For the cushion I have some old fire hose that has a polyester type outer layer, and the inner layer a tough rubber which looks like pieces of inner tubes. Hope this helps.
1954 Chevrolet Panel Truck Body to Frame Mounting Points
Side View
Click on the magnifying glass icon with the plus symbol
inside, upper right-hand corner of picture.
To enlarge picture and get the full effect.
