9 members (moparguy, Bill Hanlon, GRNHydra, Otto Skorzeny, mason86, klhansen, Gray_Ghost, mick53, Hawkman),
93
Mod | | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | I have 05 GMC Envoy buckets that are all power equipped. They have built in seat belts which is nice for this ap. Does anyone have knowledge on basic wiring to operate the seat controls? I have both pig tails attached. Also, the seats may sit a couple of inches higher than the stock seat given the height of the seat pedestal that year. I may have to consider zip cutting the floor and installing new metal. The other consideration is new mounts for the bolting part. cheers | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...do you have a ground wire from the seat to the floor? | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Not sure on the ground wire. I had a demo of seats by a fella that had an Envoy. Not sure if it has seat warmers which were controlled on the arm rest. Would have to install a switch. cheers | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | They are heated seats and the ground is the seat it self via bolts. Had a chance to see the seats work, all is good. cheers | | |
