1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | I'm thinking of picking up a 235cid with a powerglide tranny in hopes of swapping it with the 228cid 4-speed I now have in a 1953 GMC 3/4 ton. Has anyone done this or can it be done without a lot of mods? Is it worth the trouble since the current engine and tranny work ok except the lifters are noisy. My mechanical experience is only fair but I'm learning as I go here. Any thoughts? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | It is a lot easier to adjust valves than to put a 235 powerglide in a GMC. | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Bingo. You would gain nothing for all your hard work except a quieter engine that does not fit right. I like the sewing machine sound of the lifters. You can tell a lot about how your engine is running by becoming familiar with that sound. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | | | | Joined: Apr 2014 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 33 | I got a look at the engine and trans today and it was not exactly as advertised. The trans was a 3 spd manual and the engine has been sitting for 3 years so who knows what's still movable. I think by the sounds of it I'll leave well enough alone and keep what I know is working. | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | If the lifters on the 228 are excessively noisy in spite of repetitive adjustments, check the tips of the rocker arms at the valve stems. If there is a deep groove in the rocker tips, the wide feeler gauge won't read the true gap between the rocker tip and the end of the valve stem. The rocker tips can be dressed and polished to remove the grooves. Carl
