4 members (54farmtruck, Danielbolt, Wooley, 1 invisible), 110 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
Could someone give me a starting point to check,so I can possibly find out why my radio quit working? It is in my grain truck and I cannot seem to find out what the problem is. The radios an original GM with slide tuner bar for AM and FM , in my 1979 chevy truck. I checked and am getting power, and no sound when radio is turned on or off. Pat
1966 Chevy C 30 1 ton truck
you've passed the starting point, you know it's getting power but it doesn't work ... the only way to find out what went wrong is to remove it and bench check it with the proper test equipment and a schematic - which is to say you need to send it to a shop or do without wink
Thanks,bill, as soon as I can get the bin fan motors fixed again,and some other things patched up I will take it somewhere to be looked at. Pat
Try checking the grounds on the radio and the antenna.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Radio update, mice have been working under dash,created quite a mess,for now will go without radio,thanks for input. Pat
Moderated by  truckernix
