0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Could someone give me a starting point to check,so I can possibly find out why my radio quit working? It is in my grain truck and I cannot seem to find out what the problem is. The radios an original GM with slide tuner bar for AM and FM , in my 1979 chevy truck. I checked and am getting power, and no sound when radio is turned on or off. Pat
1966 Chevy C 30 1 ton truck
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you've passed the starting point, you know it's getting power but it doesn't work ... the only way to find out what went wrong is to remove it and bench check it with the proper test equipment and a schematic - which is to say you need to send it to a shop or do without  Bill | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Thanks,bill, as soon as I can get the bin fan motors fixed again,and some other things patched up I will take it somewhere to be looked at. Pat
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Try checking the grounds on the radio and the antenna. | | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | Radio update, mice have been working under dash,created quite a mess,for now will go without radio,thanks for input. Pat
