1 members (chemanic), 87 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
I located a donor chassy for my 52coe only a few miles from home for 500 bucks great shape all disc brakes 1990 c-20.(or is it p-20?) Only problem is I have to help remove the motor home body on it. Looks like 15" wheels and not rusty.
Can't wait to get started.
Question is, will the c- 20 be a good donor?
If you want to see a '50 COE,on a '72 C20 frame,check this out!
Mo' Tater
I have seen that one, really cool.
I need to find someone who can provide pictures of a build in progress.
Also, I am searching for pics of an original truck to compare to what I am starting with, under the hood where mine appears to be missing some parts,hopefully just the top radiator support. Since the hood latches differently than my 1.2 ton, I am not sure if it has the same shroud piece like where the 1/2 to hood latches in front of the radiator.
Checked out the donor today, it's not a 1990 as the guy said but an 83 pace arrow motor home on a c-20 chassis. The wheel base is around 158". I really need a shorter wheel base for the coe cab, 36"sleeper (42 on the outside) and a 6' chevy 47-53 bed.
The frame rails appear to be parallel so wondering if I can move the rear end to wherever I want to shorten the wheel base for my design. It will have to move forward about 2 feet.
Moving the rear end is no big deal. Either drill or grind the original rivets and mount it where you want it with flange bolts.
http://www.imperialsupplies.com/item/0191480
We use the same type of bolt on our semi frames. Only a little bigger. 5/8 and 3/4
Thanks , there was no way I was going to find a frame the exact length I needed. Thanks for the bolt tip also.
More information on the donor chassis,
The motorhome is on a p30 chassis. I checked the vin with gm and they confirmed that it is indeed a p30. The scrapyard folks were not sure because they are ford guys.
Probably start the slow dissection of the 53 over the winter.
