1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | I just purchased a 1955 Chevy 6400. Some modifications were made to the rear of the frame. I was wondering what frames (years, models) would be a drop-in replacement for the one I have.
Any suggestions? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 55 1st series or 2nd series? big difference, 55.2 > 59 are pretty much the same, 55.1 would be siilar to previous years, at least 54, maybe older
Bill | | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | It is a 2nd series. So you think any frame up to '59 would work? What about a 4000, 5000 vs. 6000 models? Are they different? | | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | Does anyone know where to look to find a new frame? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | LewyBoys, Not sure you will ever find a "new" frame, but you might find a used one in a junk yard. I might have on here if you're up for a road trip to Maryland... Any 1955-2 thru 1957 4400, 4500 or 6400 frame will be the same as what you have. The 1958/59 frames are different. Mike B  | | | | | Joined: Sep 2014 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2014 Posts: 30 | Thanks for the identification of which frames will work. I don't expect to find a new one but wanted to identify which truck models to search for to find one. Thanks for the tips. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | | | |
