6 members (Robert Crandall, Hotrod Lincoln, 3800GUY, JW51, Wally / Montana, 1 invisible), 78 guests, and 2 robots.
Topics128,082
Posts1,055,961
Members48,430
#1058024 09/23/2014 11:40 AM
I have been offered a good running 292 to replace my tired 235, but it doesn't come with flywheel, Bell housing or transmission.
Can I interchange this with my 235, or do I need to look for a 62 on transmission, Flywheel and Bellhousing.
Had one of these years ago in a C10 and it was a great performing lump.
Many Thanks
Rich
The bell housings are different between a 235 and a 292 engine. You'd need to find a bell housing from a newer 6 cylinder such as a 230, 250 or 292 engine. Probably have to fabricate some engine mounts too. I believe the 292 engines all use side mounts....
H Online: Content
Front mounts on a 292 are unique- - -they are offset about 3 inches from one side to the other, unlike the 194/230/250 sixes and all the V8's. A 1955-59 V8 bellhousing or a post-1962 truck bellhousing will be needed to adapt the engine to your truck. You will also need a flywheel and clutch from a late-model engine.
Thanks guys
That's what I figured, but I am in the UK and manual bell housings and flywheels are not very common out here.
Rich
