1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Does anyone know where to send my tumbler from my door handle I want to have it keyed to match my ignition switch Thanks | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Call the locksmiths in your area. Most likely you can find one that has the tumblers for older vehicles and he can match your lock to your ignition. Bring the assemblies to his shop. I did the same about a year ago and he only charged me $20. I don't know the vintage of your project, but my locksmith seemed to enjoy working on old stuff and even encouraged me to hang around and watch. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There is no such locksmith in my area, and the locksmith next door to my parents in VA could not help.
An name/address/phone number of a locksmith who does this might be quite helpful.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Tim, Come on man, you have enough old junk lying around so I know you are up to yet another parts acquisition quest. I feel certain that there has to be someone around locally as my area is certainly not a thriving hub of automobile restoration craftsman. It will just take some more hunting. Admittedly, it seems like locksmithing is a declining industry. Here is the place that did mine. It is a hole in the wall place and you will most likely freak them out with an out of state request. http://www.alodom.com/Paul | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Paul,
I think I could send them to cletis - I think he has the tools and I know he has the know-how.
"old junk lying around" - you sound like my wife.
"enough old junk lying around" - never
I do not think many of my non-drivable treasures will make it to NC in 2 years, when we immigrate/migrate.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Old truck addicts need to be thick skinned when it comes to our wives calling our treasures "Old Junk", I know I have. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | crash2012, shop around some. Do you know folks at a couple garage's?? If so ask who does it. If you have the lock out take it with you as the "code" may be on it. A couple weeks ago I took a trunk lock to the lock smith and using the code, pulled a key off his wall board and it worked....cut me a duplicate and charged me 12 bucks. They are out their. You may also ask around at a cruise-in. Someone does it!! | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Yes I have the lock out of handle and I have a key that fits my Ignition switch I just wanted to use same key for both | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Rekey an old lock is a simple task. Making an old lock take a different key is a completely different animal. The tumbler is the issue. Chevy and GMC used different keys for ignition and door lock. If I remember correctly, and that is a big if, The door lock key has a different offset at the long groove. The one that goes along the key. You could get 2 door locks and use 2 left side buttons to key both doors. But I am not sure that you can use a single key for both door and ignition. A good locksmith may be able to reset the pins in the tumbler, and match an existing key. That would give you 2 door locks and 1 key, for the doors. Getting that key to work the ignition? I don't know.
Steve H
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | GM autos used a different key for door and ignition. Trucks did not. However the only difference in the keys was the part you hold. They are B10 and B11. Trucks used a B10 for all locks. It is best to re-pin the ignition cylinder to match the door lock since the door lock cylinder usually has the code stamped on it and the ignition cylinder usually doesn't. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Check with someone in the Vintage Chevrolet Club of America. They will probably know a member who can work on locks and keys.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | I'm a VCCA member I'll check. So same key for door and lgn is correct for Chevrolet truck Thanks Cletis | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The vendors sell matching ignition and door lock sets with one key for both.
| | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Got it matched for $15 at local locksmith. I was wondering if anyone knows can you get the chrome tip/door anywhere ? Thanks | | |
