1 members (baldeagle),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 19 New Guy | | New Guy Joined: Apr 2013 Posts: 19 | I have been offered a good running 292 to replace my tired 235, but it doesn't come with flywheel, Bell housing or transmission. Can I interchange this with my 235, or do I need to look for a 62 on transmission, Flywheel and Bellhousing. Had one of these years ago in a C10 and it was a great performing lump. Many Thanks Rich | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | The bell housings are different between a 235 and a 292 engine. You'd need to find a bell housing from a newer 6 cylinder such as a 230, 250 or 292 engine. Probably have to fabricate some engine mounts too. I believe the 292 engines all use side mounts....
John | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Front mounts on a 292 are unique- - -they are offset about 3 inches from one side to the other, unlike the 194/230/250 sixes and all the V8's. A 1955-59 V8 bellhousing or a post-1962 truck bellhousing will be needed to adapt the engine to your truck. You will also need a flywheel and clutch from a late-model engine. Jerry
| | | | | Joined: Apr 2013 Posts: 19 New Guy | | New Guy Joined: Apr 2013 Posts: 19 | Thanks guys That's what I figured, but I am in the UK and manual bell housings and flywheels are not very common out here.
Rich | | |
