7 members (Gdads51, TUTS 59, Buckeye998, Robert Crandall, Greg_H, 2-Ton, 1 invisible),
362
Mod | | | Forums66 Topics128,162 Posts1,057,041 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Read,read,read, that's what I have been doing and with each article and post I read I become more and more intimidated with the though of replacing these things myself. It sounds like the balls are really tough to get off. Its a '41 1 1/2 ton. Do i need to take off the steering rods, grind the ends off then bang the crap out of them to get them out? I'm new to this but I have to do this cause Its really tough to drive at the moment with it floating all over the road.
Thanks Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I never did a '41 and certainly never did a truck that big. My experience says, yes, it's a hard job. It's even harder if you are laying on your back using a big hammer and pickle bar. You might want to ask a local shop what they think about the job labor and cost wise.
Drew
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | TK421, do NOT be intimidated by these old trucks. They can be ornary and contrary but you can do it. First thing is to get a service manual for your truck and read up on what it says. Are you may check out the Online Manuals here http://chevy.oldcarmanualproject.com/Just take your time and as you do it and run into a specific problem let us know. Guys here are willing to help. | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | If memory serves - On a 1941, you just Remove the Cotter Pin and Un-screw the end-Plug, and the Tie Rod lifts off...
A Girl Scout could do it...
No 'Pickle Bar' or Hammer needed...
| | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | If it's "floating all over the Road" chances are it is because the -
Wheel Alignment is off...( or a bent Tie Rod )
King Pins or their Sockets are worn out...
Front Wheel Bearings are loose or worn out...
Under-Inflated Tires...
Steering Box is loose or needing adjustment or ( if rare, ) worn out.
Or any combination of the above.
Rather than bad Tie Rod ends or Ball Joints.
Get the front end of your Truck up on suitably sturdy Jack Stands, and it is a lot easier to check on these things.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | It might be better to take a good look at things. The tie rod ends have serviceable parts in them. Many times you are able to replace the pucks and spring inside the tie rod ends and tighten things up to spec and be ready to go. As mentioned about, take the time to check your king pins, wheel bearings and steering box adjustments along with checking the fluid in it. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Tie rods were shot, replaced, steering much tighter. King pins are good, checking bearings and steering box tonight. Thanks for the help so far.
Andy
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Good. It sounds like you handled your worries about the job pretty well.
Drew
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | I had had the ends basting in PB Blaster for about two weeks took a few good whacks and out they popped. Unscrewing them from the bar on the other hand took a while. Imagine my surprise when neither of them had locking cotter pin. Another question, what direction should the bow in the bar face? Forward, Back, up or down.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | What "bar"? Are you talking about the tie rod? Shouldn't it be straight? Sorry, I'm not familiar with your model.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | bent tie rods are pretty common from sloppy jacking, I've found some with a piece of angle iron welded on to pull them straight  .... if it's bowed it's time for a new one  Bill | | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | Far as I recall the Tie Rod on a '41 should be "Straight".
Where did you get new Ball Joints from for a 1941 1-1/2 Ton?
I have never before heard of a Chevrolet Truck of that vintage having a bad Ball Joint. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Yes, It is the tie rod, It is in a very symmetrical V with about a 10 degree bend right in the middle. Found tie rod ends at rock auto of all places. Fit perfectly.
| | | | | Joined: Jan 2011 Posts: 212 Shop Shark | | Shop Shark Joined: Jan 2011 Posts: 212 | The Tie Rod ends fit on to the Ball Joints...they are two different things.
Probably someone drove over and caught something on the ground and bent the Tie Rod somewhere along the way.
It should not have a "Vee" in it.
Being bent like that would definitely adversely effect driving stability, and or would represent an excessive 'Tow In' making it about impossible to drive straight without constant corrections and struggles with the Steering Wheel.
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Any idea where i could find a new one?
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Looking for a new tie rod. Its bent. I just replaced the ends.
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Has anyone else straightened a tie rod end? I have and it stayed straight ever since. I don't want to recommend to anyone to do what I have done on my own truck in case that practice is inherently unsafe. I did not use heat, BTW. I figured that since it can be bent without breaking, I should be able to straighten it without damage. After straightening, there were no stress cracks. Carl
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 |
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My '56 has an angle iron brace. It was that way when I bought it and I've been driving it 9 years | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I drove a 57 for a few years with angle iron on the tie rod, until I parted out a TF with a straight rod - works OK but I don't think a mechanical safety inspection would let it by
Bill | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes I have Carl, straightened my tie rod. It had a slight wow in it when I got it, pretty common occurrence with these trucks since they hang down where anything that sticks up can bend them. They're mild steel tubing, not tempered or forged like the spindles or steering knuckles so it isn't a problem as long as the bend isn't sharp. Also because of the length they are not to strong in compression, it's very easy to put a bend in one by bumping a curb or rut in the field. I made a set of clamps to keep the tube from rotating while I reshaped mine in a press: http://www.pbase.com/dennygraham/image/121617855http://www.pbase.com/dennygraham/image/157490332By re-positioning it a number of times you can straighten them out as good as new. dg
Denny G Sandwich, IL
