4 members (52Carl, Gdads51, JW51, Bisbee), 40 guests, and 3 robots.
Topics128,062
Posts1,055,845
Members48,428
#957300 07/18/2013 6:00 PM
Ok. I have a 1961 C60 with the 261 engine. I pulled the intake and ex manifolds to replace gaskets. Well the exhaust manifold was warped and cracked. Found some used Fentons to install. My question is about the pins at the front and rear of cylinder head, should I pull them and prep the holes for studs so I get better clamping power? Or is this advised against. This is my first Inline engine and it looks to me that a fastener at the ends would help. I also want to install studs in the head as opposed to bolts when I install my manifolds. I am getting read to order a Clifford Intake as well.
The pins you refer too are screw in studs. They should back out. Many owners including me have replaced them with threaded studs to insure a tight fit manifold. Make sure your Fentons have a
straight and flat mounting surface too.
Drew
On the 250, the two end studs are threaded in to water ports and need to be thread sealed. Be sure to check your engine for this.
Joe
What about the 1956 235 truck block are the pins screw in studs? I do not want to assume anything.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
They are screw in for a '56 235.
1961 261 end pins are threaded. For anyone else asking the same question.
For anyone else asking the same question, all of them were screwing studs.
dg
Denny G
Sandwich, IL
I have Fenton's and a muffler shop installed them. I needed custom made "head' pipes for my "stacks". This question pertains for the "Do-It-Yourselfers: Are the 235,261 studs threaded in to water ports,like the 250/292's? If so,what years? THANKS!!
Mo' Tater
I know of no Chevrolet six before 1962 that is open to the water jacket on the manifold bolts.
My Blog
THANKS,Dave!Good to know.
Mo' Tater
