7 members (Shade Baby, Otto Skorzeny, GIJOE298, 1955 1 Series, Cletus1950, Youngin' Tut 59, MickeyP),
125
Mod | | | Forums66 Topics128,147 Posts1,056,806 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | Am rebuilding the brakes: This truck will never carry a load again and hardly be driven any highway distance.
1. Would I be able to get along without a booster and have adequate braking with the light use as described above?
2. If I were to install a boost system.....the old is costly to rebuild....how about installing some newer power brake that is easy to adapt to the present brake system. I'll bet some street rod folks have already discovered something that works.......I hope! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy rviator, welcome, you could run the system without a booster, but that would make the pedal effort required to stop very heavy. There are kits out there to put boosted brakes in the stock location under the floor for the slightly newer trucks (1948 and newer), but I haven't seen such a kit for your year. Does you master cylinder mount to the side of the transmission and do your pedals mount to the bellhousing? | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | For the cost of all the new stuff to convert your truck you could just rebuild what you have and drive it for another 50 years... Mike B  | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Agreed^^^, I rebuilt the brakes on my 42 1.5, and they could put you through the window if you stand hard enough. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | I agree with all of the above, I just finished this weekend the brakes on my 47 2 ton without hydro-vac and the peddle is hard and stayed up all weekend without any leakage, I rebuilt the wheel cyls. and a new master, adjusted all the shoes until they rubbed and then backed off. works great and my E-brake doesn't pull all the way back anymore. I like it!. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | master cylinder does not mount on the transmission....nor do the pedals mount to the bell housing. Thanks, | | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | Just to clarify: You rebuilt with or without boost? Thanks, | | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | Thanks......that is great to know. Am guessing that you don't find the brake pedal to difficult to push for a reasonable stopping ability....? Thanks.....!! | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | pedal is no problem, even when I loaded the truck with dirt, ya, you know theres a load but not bad at all, my other 47 has a booster and it stops just as good as this truck with a tad easier pedal. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
