1 members (Danielbolt),
163
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2014 Posts: 72 | Hey guys I found a donor truck 1951 3100 with a good windshield, but I need to have it out of the car tonight. Can anyone give me a quick rundown on how these things come out? | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | Remove center strip inside & out, then use a razor blade knife around the window rubber on the outside & then gently push out....joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Yeah if you are not trying to save the rubber gasket around the windshield, you can just cut it and remove the glass.....
John | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Hey, you weren't the guy I saw at the Quicky-mart covered in blood, looking for big trash bags and duct tape were you? Just wondering what the rush was.
| | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Why go to the trouble for used glass when new stuff is so cheap? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I agree wit you turbo, flat glass for an AD is relatively inexpensive. Most any glass that was in front of a vehicle for half a century is gonna have some surface damage not to mention the deterioration and yellowing of the plastic lamination. Mute point though, cus Jimmy Jazz pulled it out the other night, but someone else might benefit from the thread. dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Is the new glass the same thickness as the old?? I know some of the 55-57 windshield and rear window glass isn't quite as thick as the new replacement stuff is.
John | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | It's not enough difference to matter. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...it probably varies from time to time or manufacturing run to manufacturing run. I measure my glass vs the new on my panel and it was .005 with the new glass being thicker. | | |
