| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | I wondered what the rough time to replace an A.D. grille would take. I realize it depends on: rust, condition of fenders, etc. but... could people give me what time it took them to take the old one out and how long to put a new one back in. I am getting a new chrome grille and taking out my old painted one. The truck is a 1951 and is in overall good shape, i just like the looks of the chrome grille. Oh yeah...any helpful hints would be appreciated. Thanks! Brad.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Taking time out for lunch I'd say its an "all day job". Sometimes the new one will be a little finicky to bolt up but you may hit it lucky if your truck hasn't been twisted and rode hard over the years. Return and report your success after you get finished. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Grille replacement is not measured in time. It is measured in numbers of cuss words, including creative combinations of said cuss words, in addition to the total sum of the distances of thrown tools. Or, if you are an optimist, it is measured in the amount of pure joy of the experience in successfully doing it yourself. Either way, the time that it takes to do it will likely be subtracted from the end of your life. But then, you won't be able to wipe the smile off your face looking at that sweet grille when the sun shines on it. Carl
| | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | 52 Carl...you are hilarious!!! thanks for the good belly laugh!!! I figured that as Achipmunk said " probably an "all day job". Thank you for the replies guys. I'm hoping it gets here to Ontario Canada soon as our weather can start to get cold as early as October and cold fingers will just add to the amount of cuss words and time... I will definitly report back...it might just be in a few weeks. Brad. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | One final piece of advice leave everything loose until you have every bolt and lag screw in, then tighten it all down. Does not hurt to loosen the fender support bolts as well for a little extra freedom. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 |
