| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | While trying adjust the hood on our 1950 3100, I closed hood and now it won't open. I think the front of the hood is back about 1/2" from where it should be. Anybody know any tricks? unbroke
Can U believe it? My wife says: "I want an old pickup truck" so I HAD to buy it!! '50 Chevy 3100 5 window.
| | | | | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | Well, since nobody replied, I guess I will tell how i finally got it unstuck so the next guy will find this when he searches for "stuck hood." i loosened the hood mounting bracket bolts from inside the cab. I ran a wire thru the hood emblem holes and pulled while hoding the opening lever forward. popped right open.
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Unbroke: You didn't break it did you  . Good Job I didn't know how to answer you on that one. Never had that problem while I was on the fire dept. Thats what we used to open stuck hoods. popcorn The Truth is Out There (Good job and i'll remember that trick Thank you) | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Unbroke: I was talking about the Jaws of life is how we unstuck them.
popcorn The Truth is Out There (My fingers go faster than my brain and that is the truth) | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've always heard to adjust the hood without the latch installed, then once everything else is done, get it lined up properly. | | | | | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | yup, remove the latch plate first, it says in the book. some of us do first and read later...
