Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Otto Skorzeny, Ponchogl, truckernix), 111 guests, and 2 robots.
Topics128,277
Posts1,058,453
Members48,490
U
U Offline
While trying adjust the hood on our 1950 3100, I closed hood and now it won't open. I think the front of the hood is back about 1/2" from where it should be. Anybody know any tricks?
unbroke
Can U believe it? My wife says: "I want an old pickup truck" so I HAD to buy it!!
'50 Chevy 3100 5 window.
U
U Offline
Well, since nobody replied, I guess I will tell how i finally got it unstuck so the next guy will find this when he searches for "stuck hood."
i loosened the hood mounting bracket bolts from inside the cab. I ran a wire thru the hood emblem holes and pulled while hoding the opening lever forward. popped right open.
Unbroke: You didn't break it did you wink . Good Job I didn't know how to answer you on that one. Never had that problem while I was on the fire dept. Thats what we used to open stuck hoods.
popcorn The Truth is Out There (Good job and i'll remember that trick Thank you)
Unbroke: I was talking about the Jaws of life is how we unstuck them.
popcorn The Truth is Out There (My fingers go faster than my brain and that is the truth)
I've always heard to adjust the hood without the latch installed, then once everything else is done, get it lined up properly.
1954 GMC De Luxe COE
U
U Offline
yup, remove the latch plate first, it says in the book. some of us do first and read later...
