11 members (52Carl, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, Forty9, 2 invisible), 131 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#105644 09/16/2004 1:18 AM
ok i am working on a 69 chevy 1/2ton it needs cab corners ,rockers, inner rockers, and front and rear cab mounts what should i take out first and put backing tanks for any info
#105645 09/16/2004 2:56 AM
I would say the rockers first since everything else mounts to them. Then inner rockers, cab supports and cab corners. Be sure to cross brace when removing that much metal and take a lot of measurements and pictures before you start. I would strip down the doors to lighten them and hang them in their openings when you weld in your rockers and cab corners to keep your gaps tight.
There is my opinion, right or wrong,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
