| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 20 New Guy | | New Guy Joined: Jan 2009 Posts: 20 | I installed my freshly painted hood on my 54 chevy and hooked up hinges , It goes down to about 2 in. from closing all the way. It is like it is stopped at the cowl in the back. I took the hood springs off and same thing . I disconnected the hinges and spring, the hood fits good , all the way down . This was a project truck and hood was not connected just laying on truck, I discovered it was a 53 hood , that should make no difference . They modified the front Hood Emblem from a 54 to fit the 53 , that threw me off . Any thoughts ?
" Hard Times Don't Last , Strong People Do."
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Post this in the Body Shop forum. There are several threads on hood fitment problems and you should get lots of helpful answers. Good luck.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Have you followed closely, the Factory Repair Manual instructions? There are some very specific procedures which must be followed closely and in the correct order. I had to write them down line-by-line to wrap my head around them, as I found the Manual's layout of the instructions awkward. BTW, keep us posted on your progress, as I am trying to put a 54 hood on a 49, and can't find a definitive answer whether it will fit. Or maybe we can swap hoods  Carl
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...leave the hinges hooked up but LOOSE. Close the hood and if it lays down then tighten the bolts from inside the cab, raise the hood and then tighten the two bolts from the outside. Then hook up the hinges and leave them loose.....let the hood weight settle on the springs and then tighten them up. Should do the trick........ | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | I remove the springs and the outer hinge bolts. I line up the rear of the hood for proper spacing at the cowl with the inner hinge bolts snug, but movable. I then lift the the front of the hood enough to place a 4X4 block between the nose of the hood and the hood latch. I then place a 16 inch length of railroad track on the rear of the hood to force it down on the cowl, and tighten the inner hinge bolts. (I believe that this step is the key to make it fit right.) Carl
| | | | | Joined: Mar 2012 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 46 | Just a thought, is it possible the hinges can be put on the wrong side? | | |
