1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#1055760 09/12/2014 11:38 PM
I've got the rod which connects to bell crank on the frame and goes through the firewall about 2". What goes on the end of that. Anyone have pictures of what and how it attaches to the Parking Brake handle on the left of the steering column of my 58 GMC 100. Thanks, Larry
58 gmc 100 with 350 sbc
Sir Searchalot
Sir Searchalot
Bell crank end of rod has a clevis threaded on it. The handle end of rod has a little hole. Rod end fits into a hole in the Parking Brake handle, then a washer and cotter thru that little hole in rod. The end of the rod you are asking about has a 90deg bend in it. 55-59 GMC Maintenance Manual PP. 255.
Is it one piece from the bell crank to the parking brake handle? The piece I have only has enough length to go from the bell crank into the firewall about 2" and it's not threaded on the end although I could thread it. Larry
I linked the manual page picture on the other thread you asked about it, yes it was one piece to the handle, apparently someone removed yours with a hack saw, maybe your handle is missing too?
Is it just me, or are 55-59 parking brake setup just plain weird?
Carl
it's just you that's weird Carl wink the TF hand brake is fine, big improvement over the AD setup
Sir Searchalot
Sir Searchalot
One Piece. Easy to make. What exactly is on either end of what you have? Did you get a pic from Bill? See Ebay item 301288457640. Make sure you are putting it thru the correct hole in Firewall wink
Thanks guys. It looks like mine was removed with a hacksaw. I've got some rod about the same size so I may weld a piece to extend it to the ratch of the hand brake. That's the only thing I need to finish the parking brake. Larry
If you say so, Bill (not the first time that I have been accused of being weird). The parking brake rod/linkage sticking out so far into the engine bay on the TF just looks out of place to me.
Carl
Carl, you asked if it was you or the brake wink if the rod was just dangling out there it might be weird, but it's obviously attached to something, for a purpose, and the length helps reduce force required, don't need foot power
