| | | Forums66 Topics128,087 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | I've got the rod which connects to bell crank on the frame and goes through the firewall about 2". What goes on the end of that. Anyone have pictures of what and how it attaches to the Parking Brake handle on the left of the steering column of my 58 GMC 100. Thanks, Larry
58 gmc 100 with 350 sbc
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Bell crank end of rod has a clevis threaded on it. The handle end of rod has a little hole. Rod end fits into a hole in the Parking Brake handle, then a washer and cotter thru that little hole in rod. The end of the rod you are asking about has a 90deg bend in it. 55-59 GMC Maintenance Manual PP. 255.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Is it one piece from the bell crank to the parking brake handle? The piece I have only has enough length to go from the bell crank into the firewall about 2" and it's not threaded on the end although I could thread it. Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I linked the manual page picture on the other thread you asked about it, yes it was one piece to the handle, apparently someone removed yours with a hack saw, maybe your handle is missing too?
Bill | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Is it just me, or are 55-59 parking brake setup just plain weird? Carl
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's just you that's weird Carl  the TF hand brake is fine, big improvement over the AD setup Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | One Piece. Easy to make. What exactly is on either end of what you have? Did you get a pic from Bill? See Ebay item 301288457640. Make sure you are putting it thru the correct hole in Firewall
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Thanks guys. It looks like mine was removed with a hacksaw. I've got some rod about the same size so I may weld a piece to extend it to the ratch of the hand brake. That's the only thing I need to finish the parking brake. Larry
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | it's just you that's weird Carl  the TF hand brake is fine, big improvement over the AD setup Bill If you say so, Bill (not the first time that I have been accused of being weird). The parking brake rod/linkage sticking out so far into the engine bay on the TF just looks out of place to me. Carl
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Carl, you asked if it was you or the brake  if the rod was just dangling out there it might be weird, but it's obviously attached to something, for a purpose, and the length helps reduce force required, don't need foot power Bill | | |
