| | | Forums66 Topics128,006 Posts1,055,267 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Sometime ago I purchased an electric wiper replacement for my 1/2 ton GMC pickup (12 volt system.
It has never worked right, it is very slow and will only operate with one wiper blade, two blades stop it dead...
Also will not work when it rains can not wipe water off.
I have tried many times to adjust the linkage to no avail. I can easily stop the motor with my hand.
Vendor says it has been to long since I purchased the 2 speed wiper motor to have it warrantied.
I will have to buy a new one for this winter. Any ideas on where to buy a good electric wiper motor system?
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure what brand you're finding poor, but NewPort makes units I've been happy with, available at many of the vendors Bill | | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | I used the New Port unit also. Good customer service too. http://www.newportwipers.com/Oops, didn't notice that Bill's "Newport" was already a link.
| | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | I installed a newport in my truck and it works great.---Jack | | | | | Joined: Jul 2004 Posts: 2,986 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,986 | I believe the one in my truck is a Newport also. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You might want to take out the wiper pivots out of the cowl. The drag on your motor could be those. | | | | | Joined: Jan 2008 Posts: 140 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 140 | Make sure you have a good ground. Try adding a jumper from the battery negative post directly to the wiper motor body and see if it works better. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | I bought a 2-speed electric motor and switch for my 57 GMC. Got it from truckandcarshop.com $180. It fit perfect and is very strong. You cannot stop it with your hand. Not sure what brand they sell, it may be a Counterpart. If I had a complaint, it would be that the switch is a little hard turn between positions. But I expect that to get better with use. At least it is chrome and looks like the original switch. Have you tried un-hooking all the linkage from the motor, to see how strong it is then? Might be some binding somewhere?
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | If you end up having to purchase another motor, my suggestion would be to consider a NEWPORT brand. I installed one (12V, 2 speed)in my 54 3100 and am very pleased with it.
Good Luck | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | sfsutton,
Do you have an original-style radio, with the speaker on top of the radio?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Newport offers two versions
One will clear the choke cable the other will not.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Thanks for all the input...I will try the Newport wiper motor setup.
No Radio installed...yet.
I can always drop the choke cable to the lower hole for throttle cable or go to automatic choke...:)
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | newport NE4753CT wiper motor With no choke cable used NE4753CCT New Port wiper motor, used with original choke cable . Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Will the newport clear the factory radio?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Will the newport clear the factory radio? Not sure But here's a pic of one installed, looks like it won't be an issue if you get the one designed to clear the choke cable ...pic... ...pic... | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My question, above, about the Newport (or any other) after-market electric-wiper working with a radio was directed to sfsutton.
The 1954/55 Chevrolet (not 54/55 GMC) truck's radio speaker is mounted on top of the radio, and the speaker interferes with the installation of aftermarket electric wipers. The original 54/55 GM 6v electric wiper does not interfere, but holes have to be drilled through the top of the dash.
47-53 radios' speakers are below the radio.
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | [quote=52Carl]Will the newport clear the factory radio? Not sure But here's a pic of one installed, looks like it won't be an issue if you get the one designed to clear the choke cable Thank you DADS50's son (I presume). Carl
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | WOW! I guess I'm the only one with problems with the Newport wiper.  The main issue is slack in the output shaft that prevents a full sweep or fully return to the park position. I got fed up with it last week and bought the rear wiper motor from an early 90's Blazer for $20 and mounted it to the Newport bracket & it works great. Only drawback is it's single speed.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That is the first complaint I've heard of the Newport wiper Robert. I bought and installed my wipers from LMC or Chevy Duty before I knew about the Newport product. However I've had no trouble with what I've got. No orig. radio but I do have air conditioning vents at the old radio speaker and but no fit problems.
~Jim
