6 members (klhansen, Gdads51, Otto Skorzeny, Bill Hanlon, 78buckshot, Millenimech), 67 guests, and 2 robots.
Topics128,036
Posts1,055,454
Members48,422
my 3100, 235 engine with Rochester carb is sputtering (hesitating) when shifting from 2nd to 3rd gear. Once in 3rd gear and above 40mph she has pep and run ok. I've notice if I pull the choke out slightly (even with engine warm) it will sputter less.
I've done the timming by attaining the maximum vacuum gauge method
Any suggestions?
maybe fuel mixture.... probably running too lean?
Check on the movement of the power valve plunger. It should move easily without any tendency to stick (although they usually stick in the rich position). If it's not opening the ball check valve as the manifold vacuum drops the mixture will be lean on acceleration.
Sounds like Jerry is right on the money! i got the plunger freed-up,but the check ball was lodged,and the truck wouldn't even idle. At least the plunger is an easy fix. Might be a good time to rebuild the carb,though. Kits are about $20.00.
Mo' Tater
