3 members (55shaker, JW51, Gdads51), 147 guests, and 1 robot.
Topics128,070
Posts1,055,900
Members48,429
#1054376 09/06/2014 4:28 AM
I am building a 46/7 with 350/350 on an s10 frame. The steering coloumn that I have was not for an auto trans or it had a floor shift. My question, what would be a good floor shift to go with, and do they all mount to the trans. I was wondering if I would have to beef up the floor. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
you have your choice of mountings. Lokar make a transmission mounted or a floor mounted.
I used the trans mounted because it was much closer to the original transmission stick shift.
I also use the Lokar trans mounted, but not 100% happy with it. After 14 years of vibration, the cable inside rattles against the lever. Lokar suggested a couple of adjustments, but they didn't really help. A floor model will isolate any driveline vibration. Its still a vary good shifter, it has always work great, just a little noisy.
Joe
American Shifter also has a floor or trans mount shifter, but I haven't had experience with them.
You could switch to a column shift column as another option, as these cabs don't have much room to begin with. I'm very glad I went the column shift route with my truck.
Depending on the shifter you go with will answer whether or not you need to reinforce the floor. In general I would say it won't be needed, but can't say for sure as I don't know if you're planning on running a 24" lever, in which case I might suggest reinforcement.
My 46 GMC on Photobucket
Thanks for the help guys. Dave
1941 Chevy
I've been using the same b&m mega shifter for 16 years. No issues ever.
Hey there, Homer.
In my '53 resto-mod I have this Lokar floor shifter mated to a TR350 and love it.
http://www.lokar.com/product-pgs/shifters/shifter-product-pgs/nostalgia-shifter.html
Cheers, John
Originally Posted by Waves2275
Hey there, Homer.
Cheers, John
That is the same one I have in my 51 Willys wagon. Works fine.
