| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I am building a 46/7 with 350/350 on an s10 frame. The steering coloumn that I have was not for an auto trans or it had a floor shift. My question, what would be a good floor shift to go with, and do they all mount to the trans. I was wondering if I would have to beef up the floor. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | you have your choice of mountings. Lokar make a transmission mounted or a floor mounted. I used the trans mounted because it was much closer to the original transmission stick shift. | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | I also use the Lokar trans mounted, but not 100% happy with it. After 14 years of vibration, the cable inside rattles against the lever. Lokar suggested a couple of adjustments, but they didn't really help. A floor model will isolate any driveline vibration. Its still a vary good shifter, it has always work great, just a little noisy.
Joe | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | American Shifter also has a floor or trans mount shifter, but I haven't had experience with them.
You could switch to a column shift column as another option, as these cabs don't have much room to begin with. I'm very glad I went the column shift route with my truck.
Depending on the shifter you go with will answer whether or not you need to reinforce the floor. In general I would say it won't be needed, but can't say for sure as I don't know if you're planning on running a 24" lever, in which case I might suggest reinforcement. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | Thanks for the help guys. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I've been using the same b&m mega shifter for 16 years. No issues ever.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | That is the same one I have in my 51 Willys wagon. Works fine.
