0 members (), 81 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
Hi,All! A friend gave me a Rochester B,since mine had a stuck "BB",in the fuel discharge. This came off a '54 2-ton 6500,with a ' 261,B.T.W. I got it torn-down,and let it soak over the week-end. Today,I re-built it. When I tried to put the base gasket on my intake,the bolts were off about 1/4 inch! Spread was shorter than intake on my '55 261. I tried the "new" carb,without the gasket-SAME thing! I swapped the lower part,(throttle body),and it bolted right up. I just cleaned the original base gasket good,and dumped some gas in the carb.,to prime the pump. Started right up-every time,but no gas to carb-1/2-full tank! Ran the battery dead,trying to get gas to the carb! flipped the seat forward,and-LOOKY HERE! I forgot to hook the fuel line back up from the pick-up tube!! L.O.L. Maybe,if I get all my ducks in a row,I'll have this thing running tomorrow?? If you can't laugh at your mistakes,don't make any! Me?...I'm laughing all the time!! Have a GREAT day!!
Mo' Tater
Nice try.....you know somebody needs to keep verifying that motors still don't run on air alone. Thanks for checking.
I,ve got some kind of blockage in my tank. I took it out this Spring,to freshen it up a bit,before installing a new wiring harness. I connected all of the lines,(today),but still no fuel! I replaced the 5" cab-to-frame line,and blew-out the frame-to pump line. It seemed constricted,so I'm going to replace that line,as well. I was getting some fuel,at initial start-up,but then...not a drop. With 10 gallons in the tank,you'd think the gas would "siphon".but only got a drop or two,at the pump feed line. Same story at the tank outlet,(bottom of P.S. cab). That's what makes me believe I have some kind of blockage in the tank itself! I had the filler neck plugged,while in storage,but,there's got to be a reason! I'll let you know what I find out tomorrow. Probably in for another good laugh! B.T.W...For the short period of time the engine was running,I could sure tell the difference in the carb. already! I haven't even got it adjusted yet,and it IDLES!! One down,??? to go??
Mo' Tater
I wouldn't run it until you take a look inside the gas tank so you don't plug up another carb. I'd take the fuel sender out and take a look with a flashlight.
Thanks,Don! that's the plan,exactly!!
Mo' Tater
It RUNS!!
Mo' Tater
